Control arm brackets or nah?
Old Mar 30, 2017 | 10:38 AM
  #31
nthinuf's Avatar
Originally Posted by TK14
And, can someone explain to me why adjustable upper control arms are better, worse, or the same as adjustable lowers? (All adjustable, of course, would be ideal.) So many options!
Caster goes down as lift height increases. To raise caster, you need to rotate the housing again. (lower the pinion). For control arms, this means:
Tilt the top of the housing back with Shorter Upper arms, or
Tilt the bottom of the housing forward with Longer Lower arms.
When only replacing one set, and depending on lift height, some mfg's upper arms may not adjust short enough to get the caster where you want it. Some people indicate that beefier lower arms hold up in the rocks better than stock arms. And when rotating only the top or bottom of the axle, pushing the bottom forward will (minimally) increase the wheelbase, as opposed to pulling the top back. So if you decide on replacing only one set of arms - front lowers are generally considered to be the better choice.
This is not an issue with the kit you are looking at - since it includes longer lower arms as well. In your case, the lowers will set the wheelbase, the adj uppers will be used to fine tune the caster and pinion angle.
Old Mar 30, 2017 | 11:12 AM
  #32
TK14's Avatar
[QUOTE This is not an issue with the kit you are looking at - since it includes longer lower arms as well. In your case, the lowers will set the wheelbase, the adj uppers will be used to fine tune the caster and pinion angle.[/QUOTE]
Based on your response, I better understand why this kit has placed the adjustable arms on the top. Thanks!
Old Mar 30, 2017 | 08:20 PM
  #33
Dollar's Avatar
I ran the AEV brackets for three years and 6 trips to Moab. Yes I scraped them. No, they never broke off. I had absolutely no problems with them and they took the beating well.
Here's one side:
I just took them off a few weeks ago and went with Synergy fixed lowers simply because I'm changing things up.
Old Mar 31, 2017 | 03:03 PM
  #34
AirJordan613's Avatar
Originally Posted by ShutterBug
A friend of mine just ripped one of these drop brackets off the Jeep in Moab. Fine for aesthetics and on road driving. Junk for crawling rocks.
My AEV brackets survived. Water tank not so much lol.
Old Mar 31, 2017 | 04:13 PM
  #35
ShutterBug's Avatar
lol. You needed some of this.
Old Mar 31, 2017 | 04:14 PM
  #36
lol. You needed some of this. <img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=669499"/>
bring it for next time
