Which Control Arm Bushings?
I am looking to Completely replace all stock arms except front lower Rock Krawlers. These joints are lubricated with 3 in 1 oil instead of grease. They are beefy. The JKS arms appear to be swiveling on the arm rather than at the joint like Johnny joints or RK's. Are these better and worth the $ ? They appear to have more "swiveling capability" but is that really true or worth it?
I think most of the arms that use a rubber bushing on one end and a flex joint on the other end will work well. I don't like polyurethane bushings; they ride rougher, transmit more road noise, wear out faster, and frequently make squeeking noises (even the ones that have zerk fittings). I also don't like heim joints, for the same reasons I don't like polyurethane bushings.
Originally Posted by Northridge4x4
Poly is harder, Vibrates and does not last nearly as long.
If poly was better the OE's woudl use it more.
David
David
Now TeraFlex doe's use a preloaded poly spherical bushing halves around a metal ball in the Flex Joint end. This is so there's no metal on metal contact. Very easy to maintain, rebuild and quiet.
