Control Arm Install
I broke down and bought control arms (TeraFlex) for my Rubicon. Front lowers and rear upper and lowers. I'm gonna use the TeraFlex guide as a starting point for length, but what is the best way to put them on? Do I need to put my Jeep on jackstands? Should I do them in pairs (uppers or lowers) or 1 at a time. Any advice would be appreciated.
Thanks!
Thanks!
Jack stand will work fine under he frame, then put the jack under the axle to hold it up. I would do one side at a time, top and bottom.
With that said, if you know someone with a hoist, see if you could use it, your back and body will thank you.
