Control Arm Install Question
Old May 4, 2008 | 08:08 PM
grnjp's Avatar
Default Control Arm Install Question
Jeepers,
I am getting ready to do a "Franken-stall" on my 2DR JK, part of which includes Currie rear upper arms to correct the pinion angle issue. My question is, do I need to loosen or remove the rear lower control arms to be able to correct the angle of the axle?
I read the Currie Rock Jock install write up, and from reading that, it sounds they installed the lower arms, tightened them, and then did the uppers. Based on that I'm guessing I just switch out the uppers. Right?
Also, I am installing the arms on OME coils, 616 HD front and 618HD rear. Anyone else running this combo? If so, do you recall what length you set the arms to?
THX!
Grnjp
Old May 6, 2008 | 05:22 PM
grnjp's Avatar
bump.
Nobody with Currie arms has suggestions?
