Control arm length TF 4"?
Old Mar 23, 2011 | 08:36 PM
Birdog3's Avatar
Default Control arm length TF 4"?
Can any 1 share with me the length of there control arms on tera flex 4" flex arm kit . i have a 4 door and im trying to center the axels to avoid the pinch seems and keep a good pinion angle thanks
Old Mar 24, 2011 | 05:01 AM
SilverJK12's Avatar
I think you will get different answers. Tera says one length. Ppl on forum say another. I just installed mine and adjusted them until it lined up right. I still need to do some tweaking. My advice is follow the writeup. There is one on the forum already with the title with "how to install teraflex flexarms" . I would post it but on phone. Do the title search and you will see it
Old Mar 24, 2011 | 07:18 PM
Birdog3's Avatar
thank 4 the advice!
Old Mar 26, 2011 | 02:37 PM
Birdog3's Avatar
can i get any more thoughts out there?
Old Mar 26, 2011 | 03:10 PM
Abacabb's Avatar
Teraflex website will tell you...
Old Mar 26, 2011 | 07:57 PM
Birdog3's Avatar
ya those may work on a 2 door but its to short and to severe of a pinion angle for a 4-door
Old Mar 26, 2011 | 08:19 PM
Abacabb's Avatar
There should be a paper that came with the lift that tells you the measurements.
I'll tell you my measurements tomorrow if you don't find it by then.
Old Mar 26, 2011 | 08:28 PM
Birdog3's Avatar
ya i set them 2 the inst. but they are wrong the axle is 2 far foward and thepinion is to the moon, i shortened the uppers, but i need to add about 1/2" to 3/4" to all the arms just trying 2 find measurment if anyone had them ill check the post 4 yours thanks.
Old Mar 26, 2011 | 08:33 PM
Birdog3's Avatar
If you dont mind shoot me the fronts also it never hurt to double check you may have a beter setup i have a lil bump steer and the alignment shop has the disco hitting the front left coil im not to happy im asking them for a refund and taking it somewhere else.
Old Mar 26, 2011 | 08:38 PM
Abacabb's Avatar
Yeah I'll get those too. Yeah something must be off... I don't have any bump steer and my disco's aren't rubbing on anything.
