Control arm pre-load
Well, I got some of Rusty's adj. lower front control arms and hope to install them along with the OME HD lift kit from NR. I plan to set the starting length at 23" center of eye to eye. But, I need to know how to set the preload, I believe is the term on the Flex joint.
But, the flex joints came with a set screw, that is not installed. Do I just turn to the first notch in the flex joint and install it?
I just had the Rusty's installed today. Neither i nor the mechanics knew how it should be set. We just put the set screw in as it came from Rusty's. It was already lined up with an indent. Would really like to know the real answer.
