Control Arm Question
After installing my TeraFlex 3" lift and front trackbar this weekend I noticed that the rear axle had moved quite a bit forward in the wheel well compared to the front. I am a little concerned about clearing my 35" tires when I put them on. I'm thinking about just adding rear control arms because the front axle doesn't look to far off (probably because of the longer factory control arms in the front than the back). What is the opinion of just adding rear control arms rather than a complete set?
Thanks!
Thanks!
Below is a link regarding the TeraFlex flex arms. I ran my lift for about 2500 miles an did not have any issues with 35's. I just installed my complete set of flex arms last night. Comparing the factory length rear arms to the new TF arms the lowers are only 5/8" longer. The determining factor for maximum length is making sure that you will not have have any interference issues with other components.
http://www.teraflex.biz/installsheet...ms_install.pdf
