control arm questions
Old Jan 3, 2012 | 06:16 AM
OverlandJKU's Avatar
Originally Posted by jacksonbmx23
Also, how long will my stock driveshafts last with the 3.5 coils, I ride trails often but not usually anything to serious
Front shafts can last quite a while...what happens is with full flex and an automatic trans, the boot on the drive shaft tears. After it tears start looking for a new shaft....
As for the brackets, they were designed specifically for AEV's lift. There is no adjustability, so with someone else's lift you can hope they do the trick...
Old Jan 3, 2012 | 07:34 AM
jacksonbmx23's Avatar
I drive a manual. Does that make much of a difference?
Old Jan 3, 2012 | 09:07 AM
Full-Traction Suspension's Avatar
Former Member
im stepping up to 35s and also plan to go to the RE 3.5 coils as well on my 2 door. In order to correct my pinion and caster angles would i need adjustable upper or lower control arms. i will eventually get both but my budget does not allow me to right now. also, i noticed that many of the big names are pretty much the same price, is there any brand that comes out on top? i was looking at the Rubicon express, rock krawler, full traction, and teraflex.
Uppers are generally cheaper to buy and get the job done. Our control arms are 100% maintenance free, no grease, no noise.
Old Jan 3, 2012 | 09:10 AM
Hifirush's Avatar
Originally Posted by TeamApex
I've had 35s with a 4" lift for about 2yrs and it's driving me nuts with the handling lately. After a lot of hours logged searching the forum I decided to go with Rock Krawler. Majority of the threads say front lowers and rear uppers are all you need to dial the caster back in. I'm so eager to install them that when they get delivered this week I'll probably put them on in the driveway even though it's barely 20degrees outside!
I just installed a set of High Clearance RK's and it makes a HUGE difference! I wish I had done it sooner, but $$$$ usually run short..... Got these for $250 shipped to my door, not too bad
Old Jan 3, 2012 | 08:55 PM
Uppers? Lowers? Front? Rear?
Old Jan 4, 2012 | 06:09 AM
Hifirush's Avatar
Front lowers.
Old Jan 5, 2012 | 05:37 AM
Originally Posted by planman
For a 4" lift, front lowers would matter the most to fix the caster alignment setting.
And they were also saying rear uppers, will those fix the rear tires from looking like they are to far forward? You said I only need rear uppers if I get a new driveshaft but won't it also help the stock driveshaft?
Old Jan 5, 2012 | 08:36 AM
I plan on getting front lowers for sure but I don't need any in the rear right? Sorry I am being a pest, i just want to get it right the 1st time
