Control arm questions (which, brands, etc)?
I was just reading a thread about that here and it seemed like there were pretty mixed reviews. I definitely don't want to have to weld on new mounts as I am planning on doing the install on my own, and can't do any welding. Or, were the mounts something that really only come into play for somebody doing hard core wheeling (which again, isn't me)?
Ok....the OP is looking to get enough in the way of adjustable control arms to run about 3" inches of lift, and will not be wheeling hard. Why would you start suggesting a long arm kit? I get that Radius arms might be a reasonable suspension suggestion for the OP's use...but in order to get radius arms you essentially need to completely remove the existing 4 link system and switch to long arm radius arms. That's an expensive and difficult way to address minor geometry issues.
OP, simply go out and buy a QUALITY set of adjustable control arms. Front lowers should be all you truly need for 3" of lift...but rear uppers are not a bad idea to keep your pinion angle dialed in. For my money, I'd spend the couple extra dollars to go with a brand like Currie, Clayton, or ORE. The all use Currie Johnny joints - and quality, greaseable, rebuildable joints are the key to a suspension system that will last.
Made in the USA!
I have Rusty's lower front, and are very weel made! Would have gotten rear, but wear not in production yet, so I got TeraFles rear uppers.
If money is not an issue, go with JKS! You get quiet rubber bushings, which are cheaper to replace. Money was an issue when I got my fronts so I went with Rusty's. He build custom control arms and I was going to have him build me some with oem bushing on both ends, but he said he was having trouble getting oem bushings at the time and I was in a hurry.
