Control arm replacement...
Old Jul 16, 2011 | 05:19 AM
SolarJKStar's Avatar
Default Control arm replacement...
I am just about ready to start replacing my stock control arms w/ JKS adjustable CA's.
Now I simply cant afford to do 8 at once, so I am doing them 2 at a time, one set per month for the next 4 months.
My question is there an order I should follow? Which CA's should I do first? Does it matter?
I already have the JKS adustable front and rear track bars, I want to get the sway bars as well, but figure they will be my last on my list.
Old Jul 16, 2011 | 05:23 AM
orfanidisnikolaos's Avatar
As i can see you run a 4inch lift. The first pair i would buy if i were you is front lowers so you can set your caster and improve steering wheel feel (less flightly).
Old Jul 16, 2011 | 07:21 AM
Thx...
So far start with the Front LCA's
Old Jul 16, 2011 | 10:05 AM
nthinuf's Avatar
Front lower, rear upper, then the other two sets in whatever order. (you'll be fine with just the front lower/rear uppers, the second sets will just fine tune and let you position the axles forward/backward in the wheel well.)
