Control arm rubbing
Old Apr 12, 2012 | 12:12 PM
ALEXANDERJASON's Avatar
Default Control arm rubbing
Recently put rock Krawler lower control arms in the front. Now I am rubbing the passenger side arm when turning all the way to the right. I don't rub the driver side, and in fact it looks like there is still a couple of inches of clearance at full lock.
I didn't have the issue with my stock arms, or at least I don't believe I did. I know I can adjust the steering end point, but I am wondering if an adjustable track bar would solve the problem as well. I have the TF 2.5bb with an extra 1/2 inch spacer up front. I don't know how far my axle is off center, but I assume it is not enough to make the difference in rubbing or not even with the axle recentered.
Anyone have any thoughts?
Old Apr 12, 2012 | 12:35 PM
EzK's Avatar
EzK
Your axle not being centered is probably the culprit. Measure how of center you are. Either way, some rubbing isn't a big deal.
Old Apr 12, 2012 | 12:49 PM
pfd1980's Avatar
i had the same issue with my RK lcas. after your axle is centered, there is a write up on project jk which addresses the steering stop. worked great, a simple fix.
Old Apr 12, 2012 | 06:32 PM
thanks guys!
i wondered if it was worth it to get an adjustable track bar, or just work on the steering stops for the endpoints.
i may start with the track bar anyway - i don't know how far it is off - i haven't measured it - but i am sure it is off by something and it's just an excuse to buy something and tinker some more.
if it does not fix the problem, i can always go back and adjust the steering end points...
