Control arms?
Old Jul 31, 2013 | 09:43 AM
Travdd's Avatar
Default Control arms?
I have a 07 Sahara JK with a 3.5 rubicon express lift with a teraflex 1 inch front spacer. I'm running the 5160 in front and the 5100 shocks in the rear. Have 35 and 5:13 gears. Just put the lift in and it rides very rough. If I get control arms would it have a softer ride or no? Thank you
Old Jul 31, 2013 | 10:04 AM
4x4chick's Avatar
I don't think it will be "softer", but might be "smoother". What psi do you run in the tires??? Most places over inflate the tires and that cause a harsh ride. Try 28 to 30 psi if you have not done it already.
Old Jul 31, 2013 | 10:09 AM
Travdd's Avatar
Thank you. Ill try that.
Old Jul 31, 2013 | 10:36 AM
JKZinger's Avatar
No, they will help handling if they are set up right.
Probably need to get softer springs.
Old Jul 31, 2013 | 03:24 PM
Gman*2007's Avatar
The adjustable control arms will move your wheels back to center of the wheel wells and correct pinion angle.
Old Jul 31, 2013 | 04:28 PM
Collyn's Avatar
And it will correct castor and help the ride out. A lot. The castor angle is probably to low. With the angle laid back(wheels forward in relation to the upper spring/shock mount) it will ride smoother. The springs and shocks will get some more of the force sent to them vs the road impacts sent to the frame.
Sent from the fast lane while driving one handed.
Old Jul 31, 2013 | 04:33 PM
Travdd's Avatar
Thank you for the feed back.
