Control arms
I am looking to get a lift kit for my 08' 4-door Jeep wrangler. And I was wondering if the control arm's on the Full Traction 3" lift kit are longer than the factory control arm? Or are they just stronger for the flexing that comes with off roading
Thanks
Matthew
Thanks
Matthew
i too have a 4dr 08 and have been doing alot of reading. from what i know and i am no expert by no means, but the control arms are longer. when you do a lift it pulls the axles toward the center (i.e. the front axle to toward the back and rear axle toward the front) a little depending on the height of your lift. some 3 in lifts correct this by using cam bolts on the lower control arms. if there are other members that read this and it is wrong please correct.
