Control arms which do I choose?
Old Feb 6, 2013 | 07:54 AM
Hrdtyme's Avatar
Default Control arms which do I choose?
I have a 2008 Sahara with a 4" lift and 35" tires. What I wanna know is what type of control arms are good for my Jeep? Are long arms better than short? Do I really need long or are short ones ok for my type of wheeling. I'm a moderate off roader and its only a out once a month. I go to places like Cleghorn, Big Bear or even Calico. I don't know if I need long or should I just go short. If long is better in a "long" run maybe I should go there? Help me!
Old Feb 6, 2013 | 08:06 AM
Tonka_yellow's Avatar
This is like asking what is the best tire. Start looking at all the major companies. Fine a couple you like and search for reviews on here. Long arm vs short arm had a huge debate not to long ago on here.
Old Feb 6, 2013 | 10:53 AM
Hrdtyme's Avatar
What kind do you have?
Old Feb 6, 2013 | 11:01 AM
I am a broke student so I don't have them yet. If I were to buy them for a 4 inch lift.... I would go for long arms and most likely rock krawler. But that's just me, everyone has an idea of the best lift company. If I were to lift my jeep 2.5 to 3 inches I would get short arms and save the money for something else.
Old Feb 6, 2013 | 11:51 AM
afpilot82's Avatar
JK-Forum Ambassador
You will be fine with short arms. Look for adjustable arms, lots of companies make them. I run Teraflex and am very happy. Priority should be front lowers and rear uppers if you don't want to swap out all 8. Jump on Northridge 4x4 and check out your options or just call them and they will set you up.
Old Feb 6, 2013 | 02:54 PM
Hrdtyme's Avatar
great advice, thanks
Old Feb 6, 2013 | 03:17 PM
TURTLECON's Avatar
I'm a little surprised you got a 4" lift kit without any new CAs... I would think some of the stock ones wouldn't fit correctly because of the added length.
Old Feb 6, 2013 | 03:27 PM
Hrdtyme's Avatar
they fit and looks great
Old Feb 6, 2013 | 03:38 PM
shockwaveaz's Avatar
Some you can adjust without removing. I recommend currie and metal cloak.
Sent from my SPH-L900 using Tapatalk 2
Old Feb 6, 2013 | 03:42 PM
Hrdtyme's Avatar
long or short ones
