Control arms and RE 3.5 in lift
I have an '08 JKU Sahara currently with BFG 33s and have a RE 3.5 in economy lift with JKS SB disconnects coming. How important are new control arms? I like to put them off a few months is possible. Although not a DD still used on the highway often.
Thanks Tim
Thanks Tim
it really depends on you. with that much lift, you will most likely feel a little flightiness at highway speeds. some people are okay with it but, if you're not, adding a bit more positive caster will help address that. your kit most likely comes with cam bolts to do this but, i would strongly recommend against using them and just use a set of adjustable front lower control arms to make adjustments instead.
