Control Arms Upgrades
Old Mar 29, 2010 | 09:18 PM
spinlock's Avatar
Originally Posted by NVRSTUCK
what do you mean when you say "they float"?
They don't have a jam nut on the adjustment thread.
Originally Posted by sdhexpert
I bought Claytons both upper and lower front and rear. I would look at other options if I had to buy again. Johnnie joints are wearing quickly (15k miles), don't accept grease very well, zirks don't seem to work very well (and I have replaced once). Also the upper rears are really thick near the tire. Not sure if other brands are similar. When I was using the stock wheels and 285's I had to use spacers.
I had the same problem with Zerk fittings, so I remove them, cleared them with a couple of shots from a grease gun, chased the threads and re-insert the Zerks. It made greasing them a lot easier, but I haven't hit the 15K mile mark yet so I can't comment on longevity.
Old Mar 30, 2010 | 05:14 AM
sanyezhong's Avatar
JKS control arms are looking great, what about the adjustable control arms from Daystar? I see they have a complete set on the market right now.
Old Mar 30, 2010 | 05:19 AM
jessmcquaid's Avatar
I only have the front lowers but went with Teraflex and they are nice and very beefy.
Old Apr 11, 2010 | 07:40 AM
sanyezhong's Avatar
What lift height will JKS CAs work with?
Old Apr 11, 2010 | 09:20 AM
zoeydad's Avatar
0" to 6"
But worth noting is that the rear uppers are 1/2" longer than stock when adjusted to their shortest length. That 1/2" is usually just fine because you're using them to adjust pinion angle.
Old Apr 11, 2010 | 09:29 AM
sanyezhong's Avatar
Originally Posted by zoeydad
0" to 6"
Thanks for the reply! Does the JKS CAs come with installation hardware, like bolts, or I have to use the stock CAs bolts?
I have an another question, from the JKS CAs picture, I see them are very different from other adjustable CAs, in fact, the JKS CAs look like "shocks" to me, so how do they lock the position for the length?
