Converting to longarm??
Old Mar 20, 2011 | 05:31 PM
hdrider's Avatar
Default Converting to longarm??
OK,,, not that I really need to for the wheeling that I currently do BUT looking at my setup in my signiture just how much converting would I have to do to go to a long arm setup? Worthwhile in the long run?
Old Mar 22, 2011 | 03:54 AM
hdrider's Avatar
No comments??
Old Mar 22, 2011 | 05:46 AM
TenForward's Avatar
Long arms would require cutting off the stock control arm frame brackets, a new trans cross member, and 8 control arms just for starters. Search for install instructions for the many long arm kits on the market to get an idea of what's involved. I have a 4" Full-traction kit on my '09 Rubicon 4 door and love it.
Old Mar 22, 2011 | 06:50 AM
Full-Traction Suspension's Avatar
Former Member
Like tinglima said, You need to cut your factory mounts off
On the two door its a big difference in ride quality from short to long arm.
We offer the long arm upgrade that consists of frame brackets, all 8 control arms, cross member and skid plate. You need to use your coils, shocks, trackbars.
The kit retails for 1895.99 (Bolt on long arm)
http://full-traction.com/detail.php?...TID=430&NOTES=
Old Mar 22, 2011 | 08:03 AM
Pluke the 2's Avatar
I'm saving up to convert to a long arm. I also run the old man emu setup.
Old Mar 22, 2011 | 04:30 PM
hdrider's Avatar
Ok,, thanks to everyone that replied. Cutting off mounts ect. Thats what I was wondering,, just how (do it yourself) friendly a conversion it would be. Sounds like something I would have a shop do.
Next step will be to check labor costs.
Thanks again.
Old Mar 22, 2011 | 06:39 PM
Former Member
Thanks again.
I installed mine with a cut off wheel and grinder before I worked at Full-Traction. It's not hard just time consuming
Generally labor is around 1,200
