Could a bad steering box cause shimmy/wobble?
Ive been chasing my tail. Just upgraded to:
Synergy DL (flipped)
Synergy tie rod
Artec Track bar bracket (raised)
Synergy ball joints
Also running a MC adjustable track bar (welded some washers on frame side bracket)
Did all this about 1500-2000 miles ago. Just hit a pot hole today and felt the onset of death wobble coming and had to slam on my brakes to stop it.
The only thing I Can feel and see is my steering gear shaft (at pitman) has lateral movement when moving the steering wheel side to side. I measured roughly .050-.060" from my rough assessment using some calipers. I've always felt a ton of movement in the steering wheel when going over bumps. Could this be the cause? Any other ideas??
Synergy tie rod
Synergy ball joints
I've been fighting it some too did a few of the things like you, alignment, track bar, shop checked it all out, did a basic tire rotation and determined I had either bent wheel or tire separating on inside, as long as wheel is on back no wobble. If that helps.
A bad steering box will definitely cause wonky handling, but I can't really see it being the cause of a wobble with .05" of play. I remember when I swapped my steering box, there was a tag attached informing you that they use roller bearings and a bit of play is normal. This was almost 2 years ago so I really cant remember any details about it.
The only other thing I can think of would be going with properly sized grade 8 bolts. I chased wobble for a good long time and it ended up being the TB bolts thats were killing me.
A bad steering box will definitely cause wonky handling, but I can't really see it being the cause of a wobble with .05" of play. I remember when I swapped my steering box, there was a tag attached informing you that they use roller bearings and a bit of play is normal. This was almost 2 years ago so I really cant remember any details about it. The only other thing I can think of would be going with properly sized grade 8 bolts. I chased wobble for a good long time and it ended up being the TB bolts thats were killing me.
I also thought about putting my stock trackbar back to see if that changes anything (now that I flipped the DL). I was thinking maybe the MC might be softer because it moves more than I remember the stock one when steering back and forth.
I'll give the bolt kit a try - thanks!!!
I have the same issue with my JKS. The bushing allows for a good deal more movement than stock, so under the right conditions I can experience a minor wobble. I may try throwing the stock bar back on as well when it cools off a bit.
I never had a wobble, but I definitely had loose steering with my 37s. I don't want say this works for everyone, but I added a steering shaft brace and it was a significant improvement.
I wheel a lot and mostly in rocks, and I found that I could burn up stock drag link ends in no time. Worth considering an upgrade to real 1 ton ends.
Another item often over looked are the front hubs. I think I had one that lasted 10k miles and another that went 12k miles. That will start a nice wobble for you.
I never had a wobble, but I definitely had loose steering with my 37s. I don't want say this works for everyone, but I added a steering shaft brace and it was a significant improvement. I wheel a lot and mostly in rocks, and I found that I could burn up stock drag link ends in no time. Worth considering an upgrade to real 1 ton ends. Another item often over looked are the front hubs. I think I had one that lasted 10k miles and another that went 12k miles. That will start a nice wobble for you.
Anyone else making a good brace? I assume RSP is still out of business ?
I've though about buying the syngergy brace only (not trackbar reinforcement bracket) and welding it on. Not sure if that's a good idea or not.
What's the test for hubs? Just like a regular wheel bearing I assume? Jack it up, rock top and bottom? Anyone else making a good brace? I assume RSP is still out of business ? I've though about buying the syngergy brace only (not trackbar reinforcement bracket) and welding it on. Not sure if that's a good idea or not.
Yeah, RSP is long gone. I still have the latest version and have thought about producing something similar. Have to get my Jeep done first though, haha.
