Could someone explain backspacing?
So I honestly feel dumb asking this, but I don't really know how it works.
I have a 2011 jku unlimited, and I wanna run 33"s on it with maybe a leveling kit or a 2.5 lift at most right now... So I see the rim I want and it comes in 16x8 with a 4.5 backspacing and I also see it 17x9 with a 4.625 backspacing... Which would be best and why? Thanks for your help!!
So if you had a 4.5 BS and added a 1.5 wheel spacer would be like almost running a 3.0 BS rim
Most people on here recommend a 4.5 BS but with my experience once you go with a wider tire than 12.5 you might consider a rim with a 4.0 BS to make up for width of tire.
So you would say the 16x8 is better for me to run 33s on?
But 33's are usually narrow tires and a 16x8 would be fine
Yeah down the road I'm sure I'll to 35s so the 17x9 would be better even tho the backspacing is 4.625 and not 4.5?
The 16x9 and 17x9 numbers are referring to size of the rim so the first number has to match the last number of the tire you're wanting to run so if you want to run say a 33x12r16 you would need the 16x9 rim
Originally Posted by onebadrc
4.625 = 4 5/8" 4.5 = 4 1/2" Negligible difference in MOST cases. 1/8 of inch.
I'd stick to the most 4.5
