couple of regearing questions
It will be a lot cheaper to have them do it. If you do it you will buy tools that you will not likely use again, materials you will not likely use again (setup bearings), and then you will have to have them replace the bearings and shims (minimum) once you figure out you did it wrong. If the gears wear, break or make noise from improper alignment you may need another set of gears too. Let the pros do the gearing and save some money by doing other mods yourself. Once you see the requirements and research the consequences (and likelihood) of improper alignment you should reassess the risk/reward.
Originally Posted by Sommer13
Same here, highest price I've ever heard is maybe $1200 for labor, but usually shops that charge that much offer great full coverage warranties on everything they install so if it ever breaks it doesn't cost you anything but parts after the first install...
Originally Posted by blue project
Sommer what's your setup. I have a 2dr auto and bought 4.88's with 34's. It runs fine on road but off-road lacks badly. I wondering how much different it's going to be.
With 34's what you'd mainly notice is a lot more torque, but a little less gas mileage, cuz their not that big of a tire for those gears...
Can do it yourself if you have a decent understanding. You can educate yourself for certain. I don't think I'm anything extra special outside any other normal guy here and I figured it all out. It's not rocket science, and no it's not like changing your oil. But if you have some mechanical skills, and an ability to understand the relationship of how the components interact and how each affects the other, then you can probably do it.
https://www.jk-forum.com/forums/jk-w...gearing-82262/
to add, I really believe a lot of the stigma attached to doing gears must have come about by a handful of people that just slapped some gears in without even trying to learn how, they messed 'em up and now everyone believes its a magical process...it's not crazy difficult, if you can learn to do your brakes properly you can learn to regear a vehicle with a little reading...and yes some access to tools. I have reused every tool I purchased in the process of doing this job right down to the special Millar pinion flange holder when installing my new driveshaft the other day. The purchase of tools is never a poor investment.
Last time I heard of a qoute from the local Jeep guy was 1200-1500. I have to see them Tuesday for gussest welding so I'm going to get a quote. I'm not worried about screwing anything up. Between my uncle and me it can be done just really slow. I usually only have 1 day to do it. That's why I'm trying to learn as much as I can before hand. Biggest thing is I need help with is if I can have the pinion bearing pressed on before I start because I have to find a shop to do it on the weekend. Not likely going to happen around here.
During the process of determining appropriate pinion depth you will be removing the pinion and need to remove the bearing numerous times to change shim thickness under the bearing. Hence the usefullness of a setup bearing. An extra bearing that is used only during setup and mesh pattern work up that easily slips on and off the pinion without pressing so you can adjust pinion depth via shim stacks under the bearing against the head of the pinion.
A discussion can be made over that process as well with the 'potential' for difference in pinion depth due to diferences between the pinion bearing used....a setup bearing may read one depth during your work up leading to problems when installing the new pinion bearing which may be a .001" thicker or thinner than the setup...........anyways....I used the method I explain. That was just over 3 years ago with many miles and journeys in between....I'm still doing well.
Thanks black northern. That the answer I needed to know that I shouldn't be trying it. I will see Tuesday what the local shops wants for labor. If their asking crazy money I might just not regear.
