A couple things to know before you install your OME LT kit
Old Apr 25, 2009 | 01:07 PM
husker_shoe's Avatar
Default A couple things to know before you install your OME LT kit
Installed my lift myself and after the install, my Rubicon still had the factory rake to it by about 1/2" I ordered the Teraflex 1/2" spacers from David @ Northridge and installed them today. Now it sits perfectly level, but the pain in the rear was removing the bump stop extensions that I previously installed so that the spacers could be installed. I've talked to a few people who have installed this setup too and they also have the factory rake. My roommate ordered the same kit and had me install it and his Rubi had it too. Point is, do yourself a favor and just order 1/2" spacers to begin with so you don't have to do it twice. Also, been playing with the caster since the install and I've got it dialed in. I have access to an alignment rack at work so it's pretty easy for me. If you set the upper control arms to 18 1/4" eye to eye, it should put your caster where you need it. Mine is at 5.5 degrees and 5.6 degrees. Hope this helps. Very nice kit David has put together and it rides better than stock!
Old Apr 25, 2009 | 06:47 PM
rjhoop's Avatar
Old Apr 25, 2009 | 07:12 PM
casey's Avatar
huh? why are pics needed? it's pretty self explanatory.
i dont think its really necessary for him to take a photo of a coil spacer and measuring tape against a control arm. if you've installed the kit, you're going to know what he's talking about.
Old Apr 26, 2009 | 07:37 PM
pastorsteve's Avatar
Installing a 2" lift all around shouldn't change one end more than the other. If your JK sat lower in the front (not a rake) before it stands to reason that it would after the lift. I'm installing that lift this Thursday. My JK sits about 1" higher in the front than the rear now AND I'm adding a new bumper on the rear (already have the front on) so I anticipate mine sitting about level after the winch install at the same time.
More importantly, what amount of lift did you realize after the 2" suspension install?
Old Apr 26, 2009 | 08:00 PM
Pygeum's Avatar
Good to know.. . . Thanks!
Old Apr 26, 2009 | 09:25 PM
1JK's*'s Avatar
How about pics so we can see what it looked like with the rake before the install of the 1/2" spacers and then what it looked like after. That way we can see for ourselves if it is worth it to buy the spacers with the kit. Or maybe just to admire his Jeep after the install of his lift. That is what the forum is for, to share....
Old Apr 26, 2009 | 09:50 PM
mkjeep's Avatar
Yeah, don't brag about being level with no pics. That's just WRONG! Show us your JK or be labeled a troll and be banned from this forum and be hunted down and get whipped by my wife. Uh, I've been drinkin again.
Old Apr 26, 2009 | 09:54 PM
mkjeep's Avatar
Haha, that firefly stuff tastses just like sweet tea.
Old Apr 27, 2009 | 04:44 AM
ended up with 3.5" front and 3" rear
Old Apr 27, 2009 | 04:51 AM
I'll have to take some more pics as I didn't take any immediately after installing the spacers. Even though your threat involving your wife sounds pretty cool, here's some pics immediately after installing the lift........
http://picasaweb.google.com/HuskerSh...50222330980770
