Cracked our Rubicon NV241-OR Transfer Case Housing
SubscribeJK Enthusiast
How do you tell if this dampener is installed? Is this something that can be added if not already there? If so, any suggestions on where I get one?
Quote:
if you have the dampeners installed, your rear output shaft will have a large thick metal ring attached to it (between the case and the flange). you can't miss it. if you have an aftermarket 1310 or 1350, you most likely installed a new yoke and will not have this there nor could you install one. now, still on the back side of the t-case, you should find a thick round rubber disk incased with metal and it should be bolted on with a bracket off to the the side of the output shaft. here's a shot of what they would look like....Originally Posted by rocknredrubi
