cragar soft 8
The wheel will stick out 1/2" further, but the tire will be pretty much in the same place with either wheel. When you are trying to compare how much the tires will stick out, it is easier to think of wheel offset rather than backspace. In this case they are the same offset, so the tire will be in the same spot with either wheel.
I think the center of each wheel will be in the "same" spot, but the outside edge (what he's worried about if he's worried about which will stick out further) will stick out further on the 9" wide wheel.
Now, let's see if I got that right...
Let me preface by saying it's before 6am here and I've been up all night, but...
Let's say you put a 12.5" wide tire on either wheel. We already said the center of the wheel falls in the same spot. The tire is centered on the wheel. In both cases half the tire is going to stick out, 6.25" from the center.
in the market for a cheap new set of rims for my stock 07 stone white. i like the look of the cragars and they are pretty darn cheap. however, i am concerned about using heavier steel rims if they decrease gas mileage too much. anyone know how much their mpg fell when they put the cragars on their rig?
Hey Rogue (funny, I feel like I'm talking to myself)
Check out this chart under the modified tech FAQ it really helps explain things.
https://www.jk-forum.com/forums/show...74&postcount=3
LOL I was going to post that same link but I didnt want to piss anyone off. Forums can be pretty competitive!
