Cragar Wheel Help
Old Apr 21, 2009 | 05:30 PM
WindyCityGuy's Avatar
Default Cragar Wheel Help
I have a new Jeep JK and need a new set of wheels (17" x 9") with a minimum backspace of 4.5". I really like the Cragar Soft 8's but the backspacing is 5" which isnt enough for what I need. Does anyone know of a nice black painted steel wheel with the Cragar look but with a 4.5" or less backspace?
Old Apr 21, 2009 | 05:45 PM
ThinkMud's Avatar
I have Cragar V-Star's 15x8, with 3.75 back spacing, and I have had Cragar Soft 8's with 4" back spacing, but those were also 15x8. I think my 17x8's were also 4" backspacing, but can't remember.
procomp also makes the same Soft 8 look, and few other companies.
Old Apr 21, 2009 | 06:53 PM
lvdoug's Avatar
maybe blackrock?
nangulator's Avatar
I have the soft 8s, 17x9, with 5 inch BS and have no problems even aired down to 18 psi, wha are you trying to do with them
Old Apr 21, 2009 | 06:57 PM
I just installed the OME LT lift from Northridge and the rear swaybar links are rubbing bad against my 35" x 12.5" BFG Mud Terrains with the 17" x 9" Cragar soft 8's.
Your rear swaybar links are clearing ok??
MoTec's Avatar
Check out the 16" versions, too.
Old Apr 21, 2009 | 07:32 PM
nangulator's Avatar
I have a blackdiamond 3 inch (actually 3.5 inches ) no rubbing issues, no wheel spacers. It came with new rear swaybar end links and I moved the stock rear sway links to the front sway bar. I have cragar soft 8s (17x9, 5 inch BS) and 35x12.5x17 KM2s
Old Apr 21, 2009 | 07:37 PM
mkjeep's Avatar
Move your rear swaybar links to the inside of the mounts, problem solved without having to get more rims
Old May 13, 2009 | 11:31 AM
Enteric's Avatar
Ya, I'd move the links to the inside, but if you just want some new rims in the 17x9 4.5"BS the blackrock has a soft 8 that is in 4.5"BS. Quadratec sells them.
Old May 13, 2009 | 11:35 AM
riverzendz's Avatar
Why do you think you need 17x9? What's wrong with 17x8?
