Is this crazy???? 35''s and 3.73 in a 4 door
Old Aug 24, 2008 | 11:03 AM
vwJarhead's Avatar
Default Is this crazy???? 35''s and 3.73 in a 4 door
I have my 2.5'' lift on and I have my Mickey Thompson 15'' Locks and Spidertrax adapters ready to go. I am placing a tire order this week and plan to go with 33x12.5 M/T's. Now, here is the dilemma. Do I get the 33''s or pop for 35''s instead and suck it up for 6-8 mos. until I can re-gear? I have 3.73's in an 08 Sahara 4 door automatic. Is this a set up that I will want to kill myself driving daily or is it tolerable as a DD? Anyone with experience with this feel free to weigh in, I need advice......
Old Aug 24, 2008 | 11:11 AM
Rubicon_Fan's Avatar
Originally Posted by N2rock
FYI- when I was getting ready to buy tires, I was in the same dilemma as you. Someone pointed out to me that if I was even considering 35's right now, that meant I did in fact want 35's. So if I bought 33's, I would still be wondering about 35's and would just end up buying 35's later down the road. So might as well just go all the way to begin with.
It is SO TRUE!
Old Aug 24, 2008 | 11:20 AM
69thunderbird's Avatar
Default 3.73 - been there
if you go with 35" tires you will probably need new bumper, modify your rear brake light and possibly a spacer too.
my mickey thompson "35" inch MTZ tires actually measure out at 33.6". these fit perfectly without any modifications.
i road for 2 months with 3.73 rear drive and since then have gone with 4.88's on my 4 door auto. lot of diference in low end performance. more pep and power on trails.
lot of folks swear by 5.13's, which is fine if off-roading is 90 percent of your use, or you plan on going with 37+ inch tires.
think a 4.56 gear is supposed to get you back to 'stock performance" with 35" tires.
check this link out to see actual mph/rpm's for your application -
http://www.angelfire.com/fl/procrastination/rear.html
Old Aug 24, 2008 | 11:23 AM
Renzo Fighter's Avatar
Just buy the 35's!!!!!!! I have a 4dr sahara with 35 12.5 20's. Stock gears. its fine.
Old Aug 24, 2008 | 11:30 AM
JPop's Avatar
Given the first gear ratios it will be a lot more painful with an automatic transmission. I have 35s and a manual transmission on a two door and I'm not in a big hurry to re-gear.
Old Aug 24, 2008 | 11:47 AM
reddragons's Avatar
Default get the 35s
I went with the 33s and wish I had gone with the 35s. Go with the 35s.
Old Aug 24, 2008 | 12:01 PM
vwJarhead's Avatar
I should also mention that I have a 45 min drive to work each way and have an automatic. My drive is not highway though....
Old Aug 24, 2008 | 01:18 PM
Zonk 1/75's Avatar
New 35's on my 4.10 manual. No prob...........
Old Aug 24, 2008 | 02:06 PM
Oh yeah 35s and 4.10 No problem at all.. you just have to get used to it...
Old Aug 24, 2008 | 04:33 PM
vwJarhead's Avatar
............I have 3.73's in an 08 Sahara 4 door automatic. I was thinking of going to 35x12.5''s. Is this a set up that I will want to kill myself driving daily or is it tolerable as a DD? Anyone with experience with this feel free to weigh in, I need advice......
