Creaky/Rattly interior fixes?
Old Dec 6, 2012 | 05:55 AM
hamrickac's Avatar
Default Creaky/Rattly interior fixes?
Is there any way to lessen the amount of noise that comes from the cheap plastic interior and hard top?
I am seriously about to go insane, I have tried tightening every bolt I could find and it is still annoying to drive around listening to it if i don't have the stereo cranked.
Just wondering if anyone has any fixes for this issue?
Old Dec 6, 2012 | 06:13 AM
demtek9's Avatar
I have a squeak from the foam on the bar right by my head. But if you have one coming from the door area like I did, then try a few wraps of electric tape on the door latch reciever. It took away a lot of my rattle. I think if you search "tape door mod" a thread will pop up.
Old Dec 6, 2012 | 06:20 AM
navin r's Avatar
On my 11' JKUR I have the full hothead kit including the rear side windows; that helped. I also used the home depot dyna-mat equivalent on the entire floor of the Jeep; from the rear gate to the firewall and from side to side; every bit of floor is covered, some in two layers. I also put the same stuff around the front window frame; some under some of the dash pieces, and also under the interior door trim on all four doors, and I have the canvas cargo carrier on the inside of the rear gate, I put the stuff under that too. I also took the tailouts out and put some inside those large spaces. I also have the 4 factory floor mats plus plastic mats over those and I have the full hd cargo liner over the entire cargo floor and the sides of the cargo area. All that dyna-mat type stuff is entirely hidden; you can't see anything from inside the Jeep. All that stuff did make a big difference but took some time. A word of caution if you really like mud and water; I've heard that dyna-mat and its equivalent can trap water under it; I don't doubt that. I hate mud and only go through water when I have to so it's not an issue for me. Also you might want to make sure all your rollbar bolts are tight; take some time and uncover everything and tighten them up. Almost all windshield, door and rollbar bolts were loose from the factory on mine.
Old Dec 6, 2012 | 06:22 AM
Skid_Kid's Avatar
Turn up the radio!
Old Dec 6, 2012 | 08:33 AM
a4x4high's Avatar
Jeep actually has a technical service bulletin that says clunk type noise from doors can be fixed by greasing the door latch. I greased mine almost a year ago and noise has not come back. So maybe take off the tape and grease it.
Old Dec 6, 2012 | 09:22 AM
onsafari's Avatar
I have the anoying rattle/clunk coming from behind the door panel. Sounds like the latch mechinism.....UGH
Old Dec 6, 2012 | 11:21 AM
mbfrosch's Avatar
I have a new one that started up, sounds like the top of the rear drivers side door????
Old Dec 6, 2012 | 11:59 AM
nd501's Avatar
Default door rattles
Like the post above says, take electrical tape and wrap it one time around the latch where the door catches, will solve 99% of your door noise. Both my 2010 and 2011 jeeps had the noise and the fix worked on both of them. I actually did it on all 4 doors and the back hatch even though the driver side door was the only one making the noise.
Now I have a squeak in my front seat that I can't get rid of, sounds like the springs are squeaking every time there is any real movement.
Old Dec 6, 2012 | 12:46 PM
Monte417's Avatar
Same here its annoying as hell
Old Dec 6, 2012 | 12:52 PM
moe jk's Avatar
Originally Posted by Skid_Kid
Turn up the radio!
That's What I do... Wwwhhaaaaaatttt noise
