cross mounted shock.... thing...?
Old Apr 23, 2013 | 10:11 AM
[cY0t]'s Avatar
Default cross mounted shock.... thing...?
I've noticed many rigs, particularly ones running larger tires, are running what appears to be a shock mounted sideways across the front axel on what looks like the steering cross member.
Questions:
1. What is this called so I can stop calling it a "thing"?
2. What is it for?
3. How would one know if they need one?
-T
Old Apr 23, 2013 | 10:16 AM
ronin2120's Avatar
Vet Army
Steering Stablizer.
Old Apr 23, 2013 | 10:29 AM
MNTN JK's Avatar
Very good question to ask all us jeepers and anything u need to know u can find here....
It is a steering stabilizer, which is mounted on ur jeep just like u saw it. It softens ur steering when ur vehicle hits bumps. When we put larger tires on our jeeps we upgrade to a larger or stronger stabilizer to help because the bigger tires are harder on ur steering when u hit those same bumps....Hope that helps just trying to explain it as simple as I can and yes it is a shock lol....
Old Apr 23, 2013 | 10:33 AM
[cY0t]'s Avatar
Sweet.
Searched the forum for Steering Stabilizer after Ronin's reply and found a lot of threads about stock vs aftermarket, but nothing that really said what it's purpose was or what it is supposed to correct.
Thanks for the help.
-T
Old Apr 23, 2013 | 10:38 AM
holmes4x4's Avatar
Also when you go with a high enough lift from everything that i have learned it should be flipped correcting the geometry up front and keeping the stabilizer from rubbing or binding when suspension is being flexed
Old Apr 23, 2013 | 01:29 PM
ronin2120's Avatar
Vet Army
Yeah I figured you would jsut search the topic but your next question is where it will get crazy. Your going to get to hear two different thoughts on the steering stabilzer. Some people say "you need them to help with bump steer" and others will say that "if your suspension is set up correctly you don't need it". My suggestion is to do your own research and determine for yourself. People seem to be very passionate about steering stabilizers and their purpose...
Old Apr 24, 2013 | 12:50 AM
EzK's Avatar
EzK
The only reason to flip or relocate is to keep it out of the rocks.
