Crown Brake Line HELP!!!
Old Jul 29, 2010 | 07:58 PM
u-joint's Avatar
Default Crown Brake Line HELP!!!
I am currently installing the Crown extended brake lines, and things don't seem to be lining up right.
I am following WOL's write up (http://project-jk.com/jeep-jk-write-...e-installation) but for some reason the screw hole on the mounting brace for the new lines is 1.5 or 2 inches away from the factory screw hole. I tried just "going for it", but it felt like I was flexing the hard line too much so I stopped in fear of breaking it.
Do I need to drill new a new hole for this lines to mount against the frame? WOL's write up didn't mention this, and the pictures would make me think that it would mount up against the existing hole... what I am doing wrong? Is this just a tight fit?
Old Jul 30, 2010 | 04:01 AM
u-joint's Avatar
I figured it out.
Apparently it's just a tight fit. I had to pull the hard line pretty far forward to get it to fit.
Thanks.
Old Jul 30, 2010 | 04:02 AM
u-joint's Avatar
I figured it out.
Thanks.
