Crunching on Articulation
Old Oct 23, 2021 | 05:35 PM
BrightwhiteJK's Avatar
Default Crunching on Articulation
2013 2-Door Rubicon-Just had a complete 2-1/2" Rock Krawler lift installed. During Jeeptoberfest while riding the Modified trail with electronic sway bar disconnected. there developed a very pronounced crunching noise in front while running over obstacles. Reconnected the sway bar and noise seems to have gone away. Previously with sway bar disconnected on stock suspension had no issues. Is it possible that the increased articulation was too much for the electronic sway bar and I damaged it internally? Any suggestions as to whether the noise was related to some other suspension component?
Old Oct 24, 2021 | 07:00 AM
Jeff Pillsworth's Avatar
What size tires? Rim backspacing? Did you add bumpstop? It could be as simple as the tires contacting the fenders. The sway bar is fine with the articulation.
Old Oct 24, 2021 | 07:25 AM
TheDirtman's Avatar
Check to see if the sway bar is rubbing on the tubes that prodtude thru the frame. With the extra articulation the axle shift is more pronounced. The disconnect should be fine as it will spin 360 if it had nothing to stop it while disconnected.
Old Oct 24, 2021 | 11:19 AM
Tires are Mickey Thompson Baja ATZ P3 LT315/70 R17 on 17x9 rims -6mm offset and 4.7" backspacing
Old Oct 24, 2021 | 12:32 PM
Assuming you did not add bumpstop extensions, those tires will definitely hit the fenders when flexing. Likely need 2" of Bumpstop or flat fenders.
Old Oct 24, 2021 | 01:42 PM
Bumpstops were added. It is a complete X-Factor 2.5" Lift kit
Old Oct 24, 2021 | 03:47 PM
TheDirtman's Avatar
Sorry you bought that kit
Old Oct 25, 2021 | 04:38 AM
I guess you know something I don't. Should I know?
