customizing the stock drive shafts
Old Dec 2, 2008 | 10:26 PM
JK07's Avatar
Default customizing the stock drive shafts
i am thinking of buying the front and rear 1350 yokes for the transfer case from Tom Woods get the stock drive shafts cut at each end get 1350 yokes welded rebalanced and fit. Just checked the stock driveshafts are pretty strong as steel tubes the only week link is the CV style at each end...
Old Dec 3, 2008 | 04:12 AM
Piginajeep's Avatar
I've seen pictures on here of stock driveshafts twisted at tubes..
Old Dec 3, 2008 | 04:22 AM
openeagle's Avatar
The stock drive shafts are an alloy metal which makes them harder to weld to. you are better off buying new drive lines and saving your self money in the long run.
Old Dec 3, 2008 | 10:11 AM
Phishjeep's Avatar
What is the diameter and wall thickness of the stock shafts, as well as the JEReel shafts? One local place had a 2.25" .25 wall tube, while another was recommending the 3" .083 wall. What is a good combination?
Originally Posted by gt3073b
The other problems include non-replaceable boots over the slip joint and the HUGE diameter of the stock shafts. You'll have to replace the front shaft if you go with any kind of long travel suspension so they don't hit the transmission skid or exhaust.
Bryan.
Old Dec 3, 2008 | 04:17 PM
greasemonkey85's Avatar
everyone is missing the worst part of these shafts!!!! the external splines!!! dent one and know your shaft isnt going to slide in and out right. the boot is also the dumb thing too!!!
Old Dec 3, 2008 | 04:24 PM
jayrav's Avatar
Bryan.
The aftermarket driveshafts still make contact with tranny skids. Even after I had trimmed it.
Old Dec 3, 2008 | 05:01 PM
TexsDream77's Avatar
Mine didn't. Grind it more. I got the stock shaft to clear that skid. But, then it allowed my shaft to take out the tranny pan.
Old Dec 3, 2008 | 05:40 PM
jayrav's Avatar
Remember yours is 4dr, mine is 2dr. If I grind it anymore I will comprimise the integrity of the skid to do its job. A buddy and I are thinking of fabing up a tranny skid that won't interfer with my front driveshaft. Lets see.
Old Dec 14, 2008 | 06:12 PM
I know a whole lot of 2dr owners that will love you if you post pics when you're done.
Old Dec 14, 2008 | 06:19 PM
If it's the front driveshaft. We have the exact same configuration 2 and 4 door. You can cut up the skid a lot. I'll take a picture of mine tommorow if you would like.
