Cut rubi rails and tramp stamp
Old Jul 21, 2012 | 04:12 PM
Livenudes's Avatar
Default Cut rubi rails and tramp stamp
Have a 3.25 RC suspension lift with skyjacker nitro shocks I've just install toyo mt open country 35x12.50x17 and I need to know how to cut my rubicon rock rails on my 4door jkur
And I've also removed the 5th tire and 3rd break light
The vent it vertical so the poison sounder tramp stamp won't work il looks for something just like that where I can mount my license plate to it and add an led plate light
Any ideas on either of these would be amazing
Cheers
Old Jul 21, 2012 | 05:25 PM
Ryan0260's Avatar
On the rock rails, take a sawzall with a metal bit and cut about an inch and a half off them. If you cut carefully, you can put the plastic plugs back in
Old Jul 21, 2012 | 05:30 PM
SBEII's Avatar
Ryan is right. And Poison Spyder makes a cover that you can mount your license plate on.
Old Jul 22, 2012 | 12:28 AM
Lane87's Avatar
Here you go! Jeep JK License Plate Mount | JK Tailgate Protection | Poison Spyder Customs
Old Jul 22, 2012 | 06:23 AM
Zroe's Avatar
Just make sure to go over the cut part with a grinder to get it smooth and cover with some anti rust touch up paint
Old Jul 22, 2012 | 06:41 AM
RKracing's Avatar
Cheers
Do you need to fender trim a little also? Check out this link below.
https://www.jk-forum.com/forums/jk-s...4/#post2609723
Old Jul 22, 2012 | 06:51 AM
snakeyes76's Avatar
Rancho also makes a tire carrier delete plate. and its vented so when you shut the doors, you dont have to slam them.
Old Jul 22, 2012 | 04:24 PM
Livenudes's Avatar
I found out today it's either cut or by flat flares or better bump stops maybe the daystar inch spacer lift with bump stops or trade up the rc springs and get 4-6inch springs to match
The skyjacker
Old Jul 22, 2012 | 04:25 PM
Livenudes's Avatar
Also RKracing thanks for the link just what I was trying to find
Cheers
