Cutting coil springs
Depending on what type of spring it is, they may have different spring rates at top and bottom (progressive). So cutting a section out of the spring could make it ride harder or softer. Make the spring uneven. Make one spring taller or shorter than the rest. Just a few things I could see going wrong with cutting them. Just go buy some new ones. It'll be a lot easier for you.
Why are you going to lower it lower than stock? What is the lift law where you are? If max lift on your vehicle is say 3 inches, then just buy 3 inch springs?
