Anyone have the AEV 2.5" lift and 35" tires? Do I need to cut the pinch seam?
Not sure if you have to bit I say why not?
It takes no time at all and a heavy layer of jb weld and I'm 5 years into my cut job..very simple mod with lots of gain |
Originally Posted by davegill
(Post 3970233)
Not sure if you have to bit I say why not? It takes no time at all and a heavy layer of jb weld and I'm 5 years into my cut job..very simple mod with lots of gain
Sure, until you hit a large bump and your tires give you a little help.
Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy. |
Originally Posted by Invest2m4
(Post 3970237)
Sure, until you hit a large bump and your tires give you a little help. Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy.
It's just the rear right?
Have a 2.5 aev and 315 duratracs (more like a 34). Haven't cut mine and no problems here.
Originally Posted by JustJeepinWithYa
(Post 3970279)
(Post 3970237)
Why the resistance to cutting it? Literally takes 5 minutes to prep and cut. 20 to JB Weld cleanly. A little sanding after it dries and then some color match touch up paint and it will look like it came that way. They actually come from the factory with it cut now. And really, all they do is stamp cut it. Nothing fancy. Yeah mine seem to be cut from factory. |
Originally Posted by afalletta
(Post 3970218)
