Cutting rails and pinch seam
Old Oct 15, 2013 | 12:06 PM
tphin's Avatar
Default Cutting rails and pinch seam
What did you guys use and how much did you take off for 35's, just ordered mine so I wanna cut these before they come in. Thanx in advance
Old Oct 15, 2013 | 12:24 PM
Ryan0260's Avatar
An angle grinder does a good job. As far as how much to take off the rock rails, it depends on your setup. Plan on at least 1".
Old Oct 15, 2013 | 12:26 PM
conifers4's Avatar
I used an electric angle grinder with cut off wheel myself to do the seams. Easy...don't forget your eye protection.
Old Oct 15, 2013 | 12:38 PM
Yellowfin's Avatar
This.
For the rails, I think on mine we cut off like 3" on the back side. Basically, made it even with where we cut the pinch seam.
This should give you an idea. I'm on 37's.
Old Oct 15, 2013 | 12:40 PM
tphin's Avatar
Thanx for the replies and the picture helps a lot. I have an angle grinder so looks like I'm all set
Old Oct 15, 2013 | 02:41 PM
Twinkydog's Avatar
I used a sawzall and cut 1.5" off both the rail and seam.
