D rings
Old Nov 30, 2010 | 05:14 AM
largo's Avatar
Default D rings
Just installed a benchmark elite stubby front bumper and am totally satisfied with the product and the simplicity of install. I have d ring mounts on the bumper that have 1" holes, but cannot find anyone who shows a d ring larger than 3/4". Anyone know where to purchase some that will not have so much slop in the mounting hole?
Old Nov 30, 2010 | 05:17 AM
fadeout's Avatar
use rubber grommets to take up the space or ballcock washers ( in the plumbing section about a dollar each) from lowes or the home depot around the D ring and it wont slide or move all over the place.
HappyCurmudgeon's Avatar
Eternal ***erator
Time for the Ballcock shank washer jokes to commence.....
Old Nov 30, 2010 | 05:18 AM
Eternal ***erator
see?
Relevant thread: D-Ring Silencers (Stop The Clank)
Old Nov 30, 2010 | 05:22 AM
EzK's Avatar
EzK
Alot that say 3/4" really have a 7/8" pin. Check the fine print or specs. We had to drill my friends mounts out to 1" to fit the pin for his from quadratec.
Old Nov 30, 2010 | 05:23 AM
jkman77's Avatar
they make shackles [ d ring] with 7/8 " pins.
Old Nov 30, 2010 | 05:27 AM
Eternal ***erator
Auto parts stores,
Tractor supply stores (watch the rating though, some are not as high as industrial quality shackles),
online 4wd shops,
http://www.mcmaster.com/#shackles/=9xzbkl
they have 1" pin shackles available but they WONT fit most d-ring mounts with 1" holes as the coating/galvanizing etc. makes the pin larger than 1". A pin diameter of 7/8" with some rubber washers would be your best bet IMO so as to not have to modify anything. Or leave the shackles in your toolbox and only put them on when actually needed, then they wont make a racket, get lost, or stolen.
Old Nov 30, 2010 | 05:37 AM
largo's Avatar
Thanks to everyone who responded to this thread. I will get the 3/4" rings and some washers and the problem is solved..
Old Nov 30, 2010 | 03:28 PM
monkers's Avatar
google "Crosby" they make quality shackles, sometimes its misleading how they are sold, if they say its a 3/4 shackle it may have a 7/8 pin dia, and 3/4 pin dia shackle would usually be listed as a 5/8 shackle, I think it has to do with the dia of the shackle ....not sure...got to there site lots of info......they make shackles that are sorta square instead of rounded for flat straps.....they make good stuff.....
Old Dec 5, 2010 | 02:33 PM
Django's Avatar
:: Use the 'Smittybilt 3/4" D-Rings' on
a 1" Tab and all you need is (1)
Lockwasher, then use a long 18"
Crescent Wrench to tighten it...
I mean TIGHT...and guess what?
Just like it was welded on ::
D-Ring Shackle LINK:
https://www.jk-forum.com/forums/**************/iggMe
