D30 axel upgrade or D44 swap
Old Apr 2, 2008 | 02:08 PM
capt scotty's Avatar
Default D30 axel upgrade or D44 swap
I have an 07 Sahara 2 dr with the D30 front and a ARB locker in the D44 rear. I want to lock my front with an ARB but wasn't sure if I need to upgrade my front axel shafts also. If I put a locker in now and want to change shafts later will the same locker work? Would I be better off changling axel shafts now and adding the locker at the same time. The Mopar D44 is an option but I am not totally sold on its lockers durability. Has anyone done this axel upgrade on the D30?
Old Apr 2, 2008 | 03:09 PM
kidjeep's Avatar
You could buy and install an ARB then upgrade to Cro moly shafts later
OR
I believe Superior is coming out with a Super 30 Kit(don't think it is available yet?) That would have a higher spline count(than stock) shaft with the ARB to match. Hopefully someone else will back me up on this. You could check around Superior's website too.
