D30 center section material?
What is the center section (pumpkin) of my D30 made of?
Is it cast iron like a normal D30 or did they cheap out and make it of mild steel like the knuckles?
Putting a truss on my axle and want to know what will be needed to weld to the pumpkin.
Thanks!!
Thanks!!
The center section is cast iron, the tubes are cast steel. Use a high nickel rod/wire to weld to the center section and you will be fine.
BTW: Cast steel cost more to make than cast iron. Steel is used where you need a material that sees more stress and is more likely to crack if it was made out of iron.
