D50 front axle thoughts?
Old Jan 14, 2015 | 02:25 PM
Kingfrank's Avatar
Default D50 front axle thoughts?
Doing a junk yard build. Found a set of 2002 super duty axles. The downside is the front is a d50 not 60. What are your guys thoughts on this front axle. Wouldn't even be considering this route if I wasn't able to trade some carpentry work for the axles
Frank
Old Jan 14, 2015 | 05:16 PM
2climbbig's Avatar
if you don't plan on going bigger than 37s I suppose its fine. But, If I remember correctly, the pumpkin is basically a 44. So you have increase in weight but not much benefit over the D44.
Old Jan 14, 2015 | 05:18 PM
Matth's Avatar
I'm sure they are better then stock dana 30s. But i think they are limited on gear selections an lockers. I also believe the shafts are the same as 44s.
Old Jan 14, 2015 | 05:22 PM
Matth's Avatar
The tubes and C's are better than what you would get from 44 rubi!
Old Jan 14, 2015 | 09:26 PM
Kingfrank's Avatar
So not much of an upgrade...the search continues
Old Jan 15, 2015 | 04:50 AM
Maertz's Avatar
I believe you could put 60 internals in it, but i wouldn't waste the money. Even on d60s theres variations, not all d60s are the same.
Old Jan 15, 2015 | 12:23 PM
Kingfrank's Avatar
Thank you. Going to a few junkyards this weekend
