Dana 30 ARB diff cover and oem tbar
Old Jan 7, 2012 | 08:25 AM
DvsKin's Avatar
Default Dana 30 ARB diff cover and oem tbar
Hey guys, I recently installed a set of diff covers on my 07 2dr. I noticed that the track bar on the front rubs on the cover when I'm in full compression (correct term?) I have a set of rock krawler adj track bars, but it doesn't look like there is much more clearence that the stock. I have a track bar bracket attached to frame side that came with my rancho 4" lift kit, and from what I have read, that stays on there when I put the adj tbar on there. I'm just wondering if it will fix my problem if I put the RK tbars in, its cold out, and I don't want to catch frostbite if I don't have to!
Thank you
Chad
Old Jan 7, 2012 | 10:10 AM
renpia's Avatar
Thank you
Chad
Re-read your post. Not sure what kind of bends the RK TR has. Is it straight or curved at the top? Can you post a pic of it?
Old Jan 7, 2012 | 12:13 PM
DvsKin's Avatar
The stock has a "u" shape that originally cleared the oem diff cover, but now it hits on the driver side of the diff cover. Here is a pic of the RK tbar, it doesn't have a "u" just a single bend. I can't see how it would clear it, but Im probably wrong.
Old Jan 7, 2012 | 05:15 PM
tslewisz's Avatar
There's enough flexibility in the frame end of the RK bar to rotate the bend somewhat forward. It still wasn't enough for the beefy custom cover I had so I bought a Poison Spyder cover. Those and the Riddler's are the same and the slimmest covers you can get.
Old Jan 10, 2012 | 06:13 PM
SaFFFari's Avatar
what the hell man.. went out this weekend and flexed the jeep a few times and put some damage on my rear (new) G2 diff cover. I have a 2" lift in the rear with a teraflex trackbar bracket to correct the difference. this blows... I had the same issue with my front cover on my grand cherokee (also g2) and the track bar. .. i mean,... i kinda looks cool.. kinda like rock rash.. but its like, who needs rock damage, when the jeep does the damage to itself.. MY JEEP IS MASICHIST
sorry.. i needed to vent and this seemed like the best place to do so. thanks ya'll
My names brian ima jeepoholic.
