dana 30 axles
Old Mar 10, 2009 | 08:16 AM
yellow07x's Avatar
Default dana 30 axles
Today I got in to some deep snow and as soon as the tires grabed the axles broke not just the u-joint the ears were gone!!!! so what are my options for replacements and anyone have problems with the aftermarket axles? also I dont know if this matters but I have 35s and a locker.
Old Mar 10, 2009 | 05:25 PM
yellow07x's Avatar
I cant be the only one who broke there front axles...........................
Old Mar 10, 2009 | 05:28 PM
seer1's Avatar
I'd say you want chromoly's. Superior and AlloyUSA both make them. The Superiors will require you to change out the axle seals. The AlloyUSA are a fairly simple switch out using the stock seals.
Old Mar 10, 2009 | 06:30 PM
MOWrangler's Avatar
I got the alloyUSA shafts, although I never broke my stockers. I call 'em trail spares...
Old Mar 10, 2009 | 07:01 PM
Stuka's Avatar
Just curious, what size tires are you running?
Old Mar 10, 2009 | 07:22 PM
yellow07x's Avatar
Im running 35x12.50 tires but I dont think it was the tires alone that broke the axles as i had been in the deep snow before i added the detroit locker with no problems.....
Has anyone broke their aftermarkets shafts ? I just thinking they are going to be a good chunk of a dana 44 also does the 44 have axle breaking problems too?
Old Mar 10, 2009 | 07:43 PM
Evolution's Avatar
Sponsoring Vendor
You are already invested in that 30 I recomend get te aftermarket axles .
Old Nov 13, 2009 | 04:51 PM
RedneckJeep's Avatar
Unless you learn how to drive correctly, you'll break even chromemoly axles. Not trying to ba a smartass at all. We have an of roading 101 forum. You should go and read it.
Old Nov 13, 2009 | 05:54 PM
Suffolk JK's Avatar
In all seriousness, don't get cromolys. After you get cromolys, since your carrier is upgraded, now your R&P is the weak link. I rather replace a shaft every few months on the trail than chew up a R&P and be done for on the entire axle (for the most part, it will take out your carrier). Don't make your R&P be the weak link. I would NEVER get cromolys, much less $1,000 Longfields for the D30. Poor investment.
