Dana 30 Question
Old Feb 5, 2009 | 07:24 AM
ckmehl's Avatar
Default Dana 30 Question
On the new JK's front axal. I have read that in the older Dana 30's if you put 35's on them , the inerds of the axals break on you. is this still true with the newer Dana's. if this is the case i won't get 35's i'll stick with 33's instead.
Old Feb 5, 2009 | 07:29 AM
Piginajeep's Avatar
you'll be fine. Theres plenty of people running 35's on a D30.
just dont throttle it hard on the rocks
Old Feb 5, 2009 | 07:41 AM
RedneckJeep's Avatar
...and to add to PiginaJeep's post, if you add a good locker and chromemoly axles, your D30 will just about be bullitproof.
Old Feb 5, 2009 | 07:58 AM
BaltChief's Avatar
If you just do mild wheeling, do you need to add gussets for the 30's? Or even the chromollys?
Old Feb 5, 2009 | 08:03 AM
THe gussets sure wouldn't hurt a thing. As cheap as they are....I got me a set to put on when the weather warms up. I wouldn't think the axle upgrade would be necessary for mild wheelin, but again, it wouldn't hurt a thing.
Old Feb 5, 2009 | 08:05 AM
Piginajeep's Avatar
gussets are not a bad idea... but seriously you'll be fine. I doubt you'll ever beat on your JK as hard as I did on my green one and I didnt have any issues
Old Feb 5, 2009 | 08:06 AM
Piginajeep's Avatar
what are you following me around?
Old Feb 5, 2009 | 08:23 AM
ckmehl's Avatar
Default thanks
thanks for all the support. the lockers are coming. just dont's know when. i will be using stock wheels. as afar as tire size, 315/75/16 or 285/75/16. i like the stockers. not ready to give them up yet. maybe after the first year or two.
Old Feb 5, 2009 | 11:51 AM
2climbbig's Avatar
I have been wheeling pretty hard on my D30 with 35" for the past 2 years and they are still holding up just fine. Wheeling hard does not mean I am hard the the skinny pedal... just that I am hitting hard trails.
Old Feb 5, 2009 | 12:46 PM
Mossyoakman3006's Avatar
For every one who has been running 35's for a while, have your ball joints been holding up, or can you beat on them going out before long if you go with 35's?
