dana 44 aussie
so i am planning on putting a aussie locker in the front dana 30 but has anyone ran a aussie in their rear? would anyone know how it would handle on road as well as off?????? plan on putting the gears and lockers in this month
i been seeing it for about 3 months now and its just calling my name. if it is new i guess i might have to install it and be the test subject
I installed one in the front on my 2010 and it worked great. I have also Put lots of other automatic lockers in the rear axle on vehicles . if it is your daily driver and you have to commute quite a ways i wouldnt recommend it, especially on the short wheel base of a 2 door. but for off road they are amazing.
I did see a post a while back indicating that a non-JK carrier was used to install a non-JK Aussie in a rear JK 44, but I don't recall if there were any issues or custom work involved in the install. Again, might be worth a call before you purchase.
All JK rears, regardless of gear ratio (3.21-5.38), will use a 3.73 and down carrier. The JK 44 open carrier will not accept common lunch box lockers and you'll need to buy an earlier (TJ, CJ, Waggy etc) 44 open diff (3.73 down) and drill it for the appropriate ring gear bolts.
Did I answer your question?
