Modified JK TechTech related bulletin board forum regarding subjects such as suspension, tires & wheels, steering, bumpers, skid plates, drive train, cages, on-board air and other useful modifications that will help improve the performance and protection of your Jeep JK Wrangler (Rubicon, Sahara, Unlimited and X) on the trail.
I have a used Dana 44 front axle out of a 2014 Rubicon that I am building to swap into my 2011 JKU Sport. I am looking for some images of how the wiring is routed from the axle up to the frame. I have the wiring from my switch panel down to the frame that I ran when I swapped the rear axle.
There's really no magic path. I think mine might run over by the driver's side coil perch and then up, similar to where the ABS line runs. I have an sPOD right there by the ECU. You just need to make sure you leave enough slack for the axle to articulate.
