JK-Forum.com - The top destination for Jeep JK and JL Wrangler news, rumors, and discussion (https://www.jk-forum.com/forums/)
-   Modified JK Tech (https://www.jk-forum.com/forums/modified-jk-tech-2/)
-   -   Dana 44 front locker (https://www.jk-forum.com/forums/modified-jk-tech-2/dana-44-front-locker-15112/)
RCJeeper 09-04-2007 08:52 PM
I'm gettin ready to order an Unlimited X (with locker and discon) after I sell the YJ. I can't quite decide on 35s or 37s. Seems like 35s will work, but I can't get the 37s outa my head. If I do run 37s, its recommended to run the Dana 44 up front. Well I saw the rubicon D44 bolt-in for a JK w/ locker for $1459. The only functional thing seperating this setup from a rubicon is the 4:1 transfer case, for about 5000 less.
My question: If I do get the mopar axle does the X wiring harness have the axle connection for the front locker?
wayoflife 09-04-2007 09:04 PM
Unfortunately, I doubt it. More than likely, you will need to get the entire dash switch assembly for a Rubicon as well as the wiring harness for it. Either way, I'd bet it would still be a deal.
dougolupski 09-04-2007 09:22 PM
Or, many have done the same and just wired in a switch in the cab thats ran off a relay. It will save a bit of money because factory wiring harnesses are bank.
red5 09-05-2007 03:12 AM
will the Front Dana 44 be a 3.73 then?
If you are ordering the JK unlimited then it must be a 08. I thought only the Rubicon comes with 4.1 now and everything else is a 3.73 or 3.21? Is the dana 44 a 3.73 or 4.1? you might want to look into this. Also I maybe wrong but I thought the rear rubicon axle is 32 spline 44 while the others are 30 spline 44 I thought the rubicon was a bit stronger because of this?
Renegade 09-05-2007 03:27 AM
This is correct. You can't put the factory switch bank in unless you change out your entire inside wiring harness as well. This would be a ridiculous task. Then you would probably also have to have your computer reprogrammed for the locker. It is pretty easy to just run your own relays.
That's a good point. You will likely have to regear your factory rear unless the 4.10 still comes with the rear locker option.
zeeto 09-05-2007 05:09 AM
You cannot get 4.10's on an '08 X, so you will have to regear. One thing I was very disappointed with when we started looking into them. I was thinking along the lines of something the OP is planning and then throwing a atlas/stak underneath as well...
Blue 09-05-2007 09:59 AM
I bet the switch and relay set up for the Eaton E-Locker would be adaptable for it.
Probably be a lot cheaper also.
Renegade 09-05-2007 12:47 PM
It very well may, but I got all I needed from a local car stereo shop. Relay with harness, and switch for under $20. I already had enough wire to do it without buying more, but it wouldn't have added much more $$.
rramsdell 09-05-2007 02:30 PM
Check around this forum. I saw the d44 bolt in with locker/rotors, etc... for $1280.
If I find the link I will post it.
rramsdell 09-05-2007 02:36 PM
here you go.
jeepconnection
and the thread about this.
https://www.jk-forum.com/forums/modified-jk-tech-2/axle-upgrade-9273/
