dana60 hub/bearing regreasing
Hi,
So I have a prorock60 front with dynaloc hubs. I would like to disassemble the hub,bearings,etc to check for wear and replace if necessary and repack the bearings,seals,etc. I have never done this before but am mechanically inclined and perform all my maintenance and service. Only thing I don't touch is engine internals,transmissions, and diff setup. Just looking for any advice someone may have for a first timer tackling this job. Thanks |
Given how few people run them and how expensive the hubs are, I'd strongly recommend calling Dynatrac and asking them. Sort of a no-brainer.
I only have the Dynatrac Prorock 60 in the rear, but Dynatrac was absolutely useless when I contacted them with a couple of really basic questions regarding replacing the fluid in the diff
The guy had a piss poor attitude and they have no documentation regarding the maintenance matthew |
Originally Posted by Matthewd5
(Post 3994752)
(Post 3994752)
I bet he called on what type of gear oil to use. They don't specify but it really comes down to the locker you choose.
As far as the OP's question taking apart a locking hub is no big deal and is relatively simple to do. I have warns and it is only removing the small bolts that hold on the cover and a retaing ring. If you do a simple bing search you will find exploded views and instuctions on how to take the hubs apart. |
Originally Posted by TheDirtman
(Post 3994993)
As far as the OP's question taking apart a locking hub is no big deal and is relatively simple to do. I have warns and it is only removing the small bolts that hold on the cover and a retaing ring. If you do a simple bing search you will find exploded views and instuctions on how to take the hubs apart. You can also find the axle fill procedure here http://www.dynatrac.com/faq.html |
Originally Posted by JE8154
(Post 3994831)
You called dynatrac to ask them how to change your diff fluid? |
Originally Posted by Rebar-7
(Post 3995035)
He called regarding correct amount of gear oil to put in..
My local guy has installed hundreds of axles with lockers and he had the question |
Originally Posted by JKJB
(Post 3995029)
Thanks,I found a write-up but wasn't sure if it was as simple as it looks and also called dynatrac and they gave me a few tips. As for dynatrac service I have called them many times and have had great service each time. Do you recall who you have talked to? I always get rob in tech support or Steve in sales. You can also find the axle fill procedure here http://www.dynatrac.com/faq.html
Matthew |
| All times are GMT -8. The time now is 08:58 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
