Daystar Lift
Are you referring to a suspension lift or their polyurethane coil spacer kit with 1" body lift...
If its the latter, I highly advise you to stay away from it...based on my experience.
Reasons:
-BL messed with my stick shift, pops out because the sound dampening boot is stretched
-2010 has 2 less body mounts in the rear, causing a lot of stress on the 2 that are still there, causing it to squeek loudly and A LOT.
- ugly gaps between the grille and bumper and the rear bumper and body.
- installation instructions (if you need it wrenching on a JK for the first time) seemed to have been made up by a 6 year old.
- ride/handling just sucks.
and the only pro is that you can fit your 35 inch tire hah
I ran it for close to 7 months now, and I just placed an order for an AEV 3.5" premium kit. Enough was enough..
But here's a pic anyway - the daystar lift with 35x12.5 BFG on Procomp 7089's
Reasons:
Daystar make a 3 inch suspension lift that consists of 3 inch coilspring spacers, new shocks and track bar relocation brackets. There may be some other pieces that I forgot to mention but you can check it out yourself on their website.
Look down in JK Show & Tell. Stickied to the top is the Show Off Threads. Look at any 2.5" coil lift in there. You will see no height difference between a coil that gives 3" actual height and a 3" spacer.
