Daystar's Budge Boost With A Twist
Old Sep 16, 2014 | 08:18 AM
AngryRedBird's Avatar
Default Budge Boost With A Twist
Due To Privacy Concerns Post Has Been Deleted
Old Sep 16, 2014 | 08:39 AM
ob269's Avatar
I'm not sure about the jk, but with my old tj that was an option, use the stock isolator or take it out and lose a 1/2"
Sent from my iPhone 5s
Old Sep 16, 2014 | 08:43 AM
Old Sep 19, 2014 | 01:07 AM
Default Here's The Latest
Old Sep 19, 2014 | 06:15 AM
TheDirtman's Avatar
Sorry to ask, but why do you need to relocate the sway bar?
As far as death wobble is concerned it matters not between a spacer or new coil. A spacer will retain the factory coil rate in terms of ride quality but will still change things link roll center and axle shift.
Old Sep 19, 2014 | 06:24 AM
Old Sep 19, 2014 | 06:38 AM
TheDirtman's Avatar
Is there a clearance issue or something that requires the relocation?
Old Sep 19, 2014 | 06:47 AM
Old Sep 19, 2014 | 06:48 AM
TheDirtman's Avatar
On your shocks, nitrogen is added to prevent bubbles from forming when the oil moves thru the valve. They can be pressuerized or not.
Old Sep 19, 2014 | 06:49 AM
Da10A's Avatar
Brilliant way to address the swaybar, rather than using longer links. I like it.
