Death wobble?!?!
Old Oct 27, 2010 | 07:56 AM
  #21
Firedog's Avatar
Default DW
I had a recent bout with DW. Read the thread and retorqued everything. No more wobble. I will now retorque durring every oil change. Also during my inspection found the pitman arm nut was just north of being hand tight. Inspect your steering system often.
Old Oct 27, 2010 | 08:49 AM
  #22
nbro's Avatar
Originally Posted by Biff Malibu
Did you put new tires on with the lift?
no i didnt change the tires or wheels but i did get them rotated which may have something to do with it.
Old Oct 27, 2010 | 12:24 PM
  #23
rinkishJK's Avatar
Originally Posted by planman
Maybe I will work on making some youtube videos of the steps of the checklist so that people can see how simple it really is.
Sent from my DROIDX using Tapatalk
That's a great idea if u got time.. some ppl, myself included, can follow and use pics and video better than text.
I have a short attention span, but videos keep my mind interested...
sent from DroiD.
Old Oct 27, 2010 | 01:33 PM
  #24
storch's Avatar
If you get under the jeep and have someone turn the wheel back and forth, you will notice the OEM track bar flexes quite a bit in addition to the bushings compressing and flexing,
with my 3.5 lift I ditched the lower aftermarket track bar bracket and OEM track bar, I added a JKS adjustable trackbar and death wobble after hitting a bump is gone ahthough I still get more stearing wheel shimmy than when It was at under 3" lift
Old Oct 27, 2010 | 02:28 PM
  #25
Biff Malibu's Avatar
You found the problem. Get the tires balanced, and your shimmy will be gone.
Old Oct 28, 2010 | 08:05 AM
  #26
nbro's Avatar
UPDATE. my wheels not being balanced probably isnt helping but i looked at the passenger side coil and it is bowed so much that its hitting the frame. im assuming this is the real problem and is happening because my stock trackbar is too short. im ordering up an adjustable and hopefully that will do it. BTW thanks to everyone for your help and suggestions
Old Oct 28, 2010 | 08:55 AM
  #27
nbro's Avatar
its not a shimmy this is a full on violent "rip the front end apart" wobble
Old Oct 28, 2010 | 01:31 PM
  #28
The Budd's Avatar
DW is easy to diagnose and fix.
Sometimes this subject is kind of like that "you can lead a horse to water, but you can't make him...follow a simple inspection checklist to diagnose and fix DW":
Planman, love your article. Recently had a 3.5 lift installed on my 09 sahara unlimited with only 16000 km. Never a problem, but right after the REAL DW when hit even a small bump. 4x4 centre who installed tried everything in your post to no avail. They changed my tires and problem resolved! Thoughts on this?
Old Oct 28, 2010 | 01:32 PM
  #29
Call it what you want, but if you had a "death wobble" you would never make it to 40mph.
The axle not being centered will not cause the wobble.
Old Oct 29, 2010 | 07:55 AM
  #30
nbro's Avatar
i think if i threw a wheel weight it would be a steady wobble. this wobble only happens when i hit a bump and doesnt stop until im down to 5 or 10 MPH. on a smooth road i can still run 60mph with no problems. im getting them balanced tomrorrow just in case and have an adjustable trackbar on the way. wont hurt either way..
