Death wobble
Old Feb 21, 2011 | 05:44 AM
bejacker's Avatar
Question Death wobble
After going out offroading one day, i started to get the death wobble. What all causes this, is there one thing i can replace, such as ball joints, instead of the whole steering, to get it back to normal. Right now it is so bad that i can't even drive it any more. Any help would be appreciated. Thank you
Old Feb 21, 2011 | 06:02 AM
JK084's Avatar
Search for it. Planman had a nice writeup. It's been discussed many many times.
Avoid driving it if you can.
Old Feb 21, 2011 | 06:56 AM
Full-Traction Suspension's Avatar
Former Member
Check the torque with a torque wrench on the trackbar bolts, and then the rest of the suspension.
Old Feb 21, 2011 | 07:43 AM
Hellbound13's Avatar
I also recommend while you try to fix it that you report this very dangerous issues here..
https://www-odi.nhtsa.dot.gov/ivoq/online.cfm
Old Feb 21, 2011 | 06:04 PM
jrylb73's Avatar
More than likely it is your Track Bar, It should be torque to at least 125ft lbs while the vehicle is setting on the ground.
Old Feb 21, 2011 | 06:13 PM
u-joint's Avatar
You should put that in your signature
Old Feb 21, 2011 | 06:28 PM
Ktonrider's Avatar
Mud in your rims throwing everything off balance maybe??
