Death wobble
Old Mar 10, 2011 | 07:14 AM
Lomax-dtl's Avatar
Default Death wobble
Can a steering stabilizer that is messed up cause the death wobble?
Old Mar 10, 2011 | 07:15 AM
u-joint's Avatar
Nope
See: https://www.jk-forum.com/forums/show...es-and-Wobbles
Old Mar 11, 2011 | 03:32 PM
JKAbomb's Avatar
I would check your track bar holes and bushings. Also your ball joints could be causing if they are extremely worn. Mine was a combination of both.
Old Mar 11, 2011 | 05:17 PM
dave810's Avatar
Just replaced my ball joints and all 4 tie rod ends today. Drove it around and everything feels ALOT better. As people have mentioned the OEM ball joints are wearing out fast. follow planmans tips for checking out death wobble.
Old Mar 12, 2011 | 05:39 AM
Lomax-dtl's Avatar
It the ball joints they are wore bad and it's only been 24,000miles. Which aftermarket ball joints are the best?
Old Mar 12, 2011 | 05:57 AM
wayoflife's Avatar
JK-Forum Founder
they aren't cheap but, the dynatrac prosteers are "the best". probably the last set of ball joints you will ever need to get again.
http://www.northridge4x4.com/proddet...d=DYN-PROSTEER
Old Mar 12, 2011 | 06:01 AM
sringer's Avatar
That set is up and lower right?
Old Mar 12, 2011 | 07:08 AM
wayoflife's Avatar
JK-Forum Founder
yes - uppers and lowers.
Old Mar 12, 2011 | 07:49 AM
Runewolf1973's Avatar
Should the ball joints be covered under warranty?...even if I have a lifted Jeep and bigger tires?
Old Mar 12, 2011 | 07:58 AM
u-joint's Avatar
I wouldn't count on getting that covered. They'd argue the larger tires put undue stress of the OE ball joints.
